20mm Round Multi-use Bases
  • I'd like for 20mm Round Multi-use Bases to be released.  They fit within the already existing 25mm rounds, unlike the 20mm squares which would poke out the corners, and also allow troop facing to be flexible in larger formations (spears for example).  Right now the only options to match my existing WGA 25mm rounds are pretty limited, plus they wouldn't have the magnet hole/lip feature or be the same thickness.
  • i would like to see these as well, in part because a lot of games like Kings of War still use a 20mm square base as the foundation of their movement trays/multibases sizes, and with the new line of sabot movement trays it would be nice to have options for round bases and sabot movement trays in those sizes that also still allows players to use those same figures in skirmish games.
  • @Ilostmycactus Umm, while 20mm would be good for epic 10mm minis, 20mm rounds are  too small for 28mm figures (even for true scale ones like the LOTR minis GW does), should just be focused on epic.
