A simple Aztec conversion
  • Working on a new batch of of Aztecs.
    As you can see I have added some jewelry. This is how I did it. It’s very easy to do. You will need a 1/16th and a 1/8th hole punch and some liquid plastic cement. I’m using Mr. Hobby but you can use Tamiya or what other brand you like. Punch out some hole and I just glued them to the neck line of the of the Jaguar suit I also made a larger earring for the Scorn . That’s it, a very easy conversion for the Aztecs.
  • did you punch those using plasticard?
